Bias
The drive bias, also known as voltage margin, describes the number of voltage levels used when driving the LCD. Bias is defined as 1/(number of voltage levels-1). The more segments driven by each driver, the higher number of voltage levels are required.
The optimal bias is selected by the LCD designer.
